Hi Guys,
I've been trying to fix my friends PC that I built him last summer and I thought I'd try pushing the overclock a bit further as I left everything on stock volts when I built it.
I got his E6600 to 2.8Ghz on 1.35 and it works fine there.
The weird thing is that CPU-Z says the voltage is lower than what I'm setting in the bios, so which should I believe?
I've currently got it sat @ 3.4Ghz on 1.425 volts in the bios and CPU-Z is saying 1.392.
I've read that for longevity you shouldn't push past 1.45 on air.
The motherboard is a Gigabyte P965-DS3.
