- 10 Nov 2011
- Boston, Lincolnshire
Well guys the setup is done and leak tested, running a tri sli setup now but the problem is cabling.. Only have PCIe cables for 2 cards, found these Phobya 300mm 6 Pin PCI-E to 2 x 6 Pin PCI-E Y Extension Cable : Sleeved Black
And could anyone tell me if I could use these? Run 2 of my cards using these with a power cable from psu while top main card running of the 2 direct power cables of my semi modular psu? Hate the look of the mocked up molex cable with the 2 pcie to molex cables I have
