- 27 Jan 2003
- Chesterfield, UK
Hi,
Looking for some advice.I have about £350-400 to spend on a case and the water cooling kit including the blocks, which will cool a X2 4400 & 1900/7900.
My train of thought at the moment is a Swiftech H20-220 Apex water cooling kit. Currently using an Asus Vento Case and I am guessing that this kit won't fit although mounting the rad externally looks likes a possibility? Assuming it doesnt fit which case do people recommend? I like the look of the Lian Li V1000 ? Any suggestions ? Must be in black and I'm looking for a easy mod for a bodge free rig.
Is this still the water cooling kit I should be looking at for this sort of price range? I was going to go for a Koolance PC3-725. Built a few watercooled rigs in the past but always ended up a bit of a pig. Worked well but always ended up a BagOCrap because of things being a tight fit.The kit needs to run whisper quiet normally but for benching have the power to cool or better still run whisper quiet with some good overclocking at the same time.
I have been going around a bit in circles so any help would be greatly appreciated to get the most from my money. Needs to last me a while
Cheers for any input
Dodgiest manufacturer's specifications - ever!
. What fan controller would you recommend m8?
