- 1 Aug 2006
Hi guys
I have a quick question
I have recently changed my watercooling loop from the cheap one that was included in my kandalf lcs.
I changed the cpu block to a d-tek fusion and added a EK 8800gtx block and switched everything to 1/2" pipe. but my temps are now worse at the same overclock (using the thermaltake kit I was at 32 degrees idle with my 6600 @ 3.6 ghz now I am at 42 idle. under both kits the cpu hits 60 degrees full load)
I also added a 120.1 black ice extreme rad to the loop inbetween the cpu and gpu.
I think the problem might be the original 120.3 rad as I think it is killing the flow through the whole system due to the tiny inlet/outlet pipes on the thermaltake rad (does that sound possible).
So my question is what rad should I be looking at buying next (if it is the rad)? and why am I getting a 20 degree jump between idle and full load using the parts I have do you guys think my cpu might be concave and need lapping?
Thanks for your help
You also have to figure in the fact that as you are using thicker tubing. Your pump is having to pump a lot more water around and may not be able to cope so well as its head pressure will be significantly reduced - blow through a straw then blow through a hosepipe and you will catch my drift
