- 25 Feb 2007
- leicestershire
hi everyone, I would really like some advice with this...
so as if squeezing an ATX board into the case was not enough,I just think it could look a little better with a custom loop rather than a closed one.
so a couple of questions:
does some of my old gear still cut it? (ddc1 with res top and EK supremem block)
figured it should be a deeper/larger radiator (140mm?) or should i go all out and install a 240mm too? (I was thinking of going SLI so fans would not fit up top, can you have a non fanned radiator or is that pointless?)
rough idea using some old kit to where things would go, is it going to look messy?
so I think what i am really asking is, is it worth going custom just to try and achieve a better look? and is it worth going custom just for a single 120/140mm radiator?
