Help with WiFi Bridge or best go Homeplugs
20 Apr 2008
West Midlands
Basically my eldest has moved rooms and the WiFi signal to his bedroom is now very weak for his PS4.
I've hooked up and old D-Link 615 running DDWRT as a wifi bridge which has helped but not perfect as the speeds he gets still isn't great.
So i was looking at going home plugs but my concern is it's need to be located via an extension due to limited space to run a passthrough home plug. Would this hinder the speeds to his room as i know from old these don't like being placed in an extension socket?!
any help would be appreciated.
I wouldn't expect one to work in any extension lead that has filtering. That means any surge-protector type ones.
If you can use a basic as possible extension with no extra components though I don't see why it wouldn't work.
I have run homeplugs through an extension cable, not ideal and you do see a performance hit. If it would help get a pass-through wall plug that the extension cable then plugs into and run a short wire or has a wireless AP in that pass through home-plug.
Just a note, but using WIFI to bridge, uses up half the speed of the wifi too!
Always best to go cable over WIFI in almost every job.
