- 3 Dec 2003
- Sunderland
Hi all,
I have just upgraded my motherboard and had trouble connecting to the net through my wireless network afterwards.
My router is an orange livebox and was originally on a WPA/WEP setting. On this setting, the network is connected but is stuck on the assign IP address stage.
After a lot of playing (buying 2 different wireless adaptors), I eventually found that the only way I can connect to the net is if I have changed the wireless setting from WPA/WEP to WEP only.
However, this did not solve the problem completely. I can connect to the internet but is still stuck on the assign IP address. The card also cut out after 10 mins.
I then tried disabling the security and after that, it works perfectly.
Although I set the router to only accept the mac address of my pc and my laptop, it does not feel very secure and therefore want this sorted out quickly.
Please help.
Thanks in advance.
Please help.
Thanks in advance.
