Hi
I'm using a Linksys WAG54GX2 which is wire to my main PC and I'm trying to get my wifes laptop connected.
So far the laptop can see and is connected to the wireless network. However, when I try to open up MS explorer it is trying to do so through here works Ipassconnect software.
I'm not sure how to get round this so I created another connection for explorer:
>Tool>Internet Options>Connections>Add>Connect to the internet via broadband.
I then enter my ISP username and password.
I then go into >Properties>Networking> and on Internet Protocol TCP/IP > Properties and I then enter the DNS server address as I see it on my Linksys set up.
As you can tell its all a bit of trial and error trying to get it to work.
Any ideas how to get this to work?
Thanks for any help
S.
PS Another thought - when I add an internet connection should I be using the VPN option?
Thanks for any help
S.
