Help with wireless installation - card missing ?
30 Apr 2003
jarrow
Just been around to my sisters to set up a wireless connection on her laptop, which i thought had a wireless card built in.......
Here are the laptop specs
Advent 7096 Laptop
Specification
CPU AMD Mobile Sempron 3000+
BIOS AMI BIOS. Press DEL to enter
Chipset ATI Radeon Xpress 200
Memory 1GB 200pin DDR-333 SODIMM (2 memory slots. Max 2GB)
Hard Drive 40GB Hitachi 4K40 ATA HTS424040M9AT00
CD Drive DVD±RW
Screen 15.4" widescreen TFT (native resolution 1280x800)
Video Card ATI Radeon Xpress 200M IGP (128mb)
Sound Card Realtek AC'97 audio
Network Card Realtek 8139/810X (onboard)
Marvell Wireless Card (possibly the Libertas 802.11g/b) *
Modem Agere systems AC'97 modem
PC Card None
Ports 4x USB 2.0
1x LAN
1x Modem
1x Headphone
1x Microphone
1x S-Video
1x VGA
1x Kensington Lock
Touchpad Synaptics Touchpad
Power Supply Lite-On PA-1700-02
Battery Sole Energy Corp. Either a EM-320L2S (battery life approx 1hr) or a EM-G3302L2 (approx 2hrs)
Dimensions 40 x 355 x 273 (HxWxD in mm)
Weight 2.85kg
Made By ECS 331
* To switch the wireless on/off use the button to the right of the power button.
So i hit the button mentioned and nothing happens, i check the device manager and there is not a wireless card under network adaptors so am i right in thinking there isnt one fitted ?
Am i missing something or is there just simply not a card fitted regardless of the specs above.
Did any of the empty expansion bays have what looked like two ends of an antenna wire inside a plastic sleeve?
Hmmm... If nothing is showing in device manager and nowt happens when you use the Wireless on/off switch I'd be tempted to say it doesn't have one or it's broken.
Is it still under warranty?
I will check the expansion bays out on the bottom of the laptop. The laptop i think is about 4-5years old. This is the first time that the wireless facility has been tried. The problem is that the original packaging and instructions are no longer available so the the specs for the laptop are what i pulled from the net so thy could be refering to an updated version.
The wifi slot is under the keyboard, press the little tabs at the edge of the keyboard bottom edge one by one and the keyboard will pop out, then there is a silver panel 4 screws it should be under there.
