Do I have to add the ip of the range extender to each and every pc on my network or just the ones that will be accessing the signal from the extender wirelessly. The thing is I only wish to use the extender on a couple of pcs not connected to the network in another room.
The problem is I cannot get a signal in the other room and so intend to use an Edimax powerline connector from the router to feed a signal into the other room via the AC. I then intend to hook the extender to the powerline adaptor in the other room to provide a wireless connection.
