help with wireless router - adding security
12 Feb 2006
Surrey
trying to add a security key to the wireless router i sometimes use but trouble is i have no clue how i get to its settings.
Dont know if this helps but it's plugged into a wired router and i connect via my laptop but also trying to connect via n95.
its for the n95 that im actually doing this as im having troubles connecting to net with it over wifi by getting a message saying "no gateway reply" and apparently this might fix it.
anyway how do i change the settings of the wireless router?
The one i got is d-link air xtreme g 2000+
