Help with Wiring power button on Zalman Z9 Plus
12 Jun 2009
Hello Guys,
I have a Zalman Z9 Plus ATX Mid Tower.
The other day I removed the front panel with the subtlety of a fat goblin walking in a garden of roses and I totally ripped the wires apart from the power button :/
There is 4 wires, two greens, a white and a black one.
I am planning to buy a soldering iron to repair it but I am unsure of what cable needs to be plugged where, would any of you be able to give me some guidance please ?
see picture below
Thanks a lot
Is this an illuminated switch? You should find that there'll be two pins for powering the led. They'll be polarised so one will be + and one perhaps to that G terminal or something. As a guess I'd say the white is the +v and the black is ground.
If you wire backwards nothing bad will happen. It just won't light up. G could also be a cavity number. Hard to say. I'd use a multimeter to determine the switching contacts if it were mine.
The two greens will be the switch circuit and can be wired either way.
Next time don't be so clumsy :P
