Help with xbox live at uni
11 Apr 2006
London
Basically can't connect run the test and it says the MTU is not high enough. Is there anything I can do to increase bearing in mind I have no access to the control of the network.
If you can't change the network is their not a setting on your xbox to reduce the maximum transmission unit used.
