Help, wold my PSU be powerful enough for crossfire
7 Nov 2010
Doncaster
Hi guys
I was thinking of buying 2 5850/crossfire
I've got an antec Truepower 650W (new one)
here's what OCuk says about it
NVIDIA™ SLI™ - ready certified
- 80PLUS® Bronze Certified saves energy and lowers your electric bill
- DC to DC voltage regulator modules for greater system stability
- 120mm PWM fan runs up to 50% quieter than standard fans
- Advanced Hybrid Cable Management improves airflow and reduces clutter
- Double layer PCB optimizes cooling efficiency and allows for heavy duty components
- Universal Input and Active Power Factor Correction
- Supports dual GPUs and dual/quad core CPUs
- 4 +12V output circuits provide stable power
- ATX12V v2.3 and EPS12V v2.91
- 1 x 6 pin and 1 x 8 (6+2) pin PCI-E graphics card connectors for TP-550
- 2 x 6 pin and 2 x 8 (6+2) pin PCI-E graphics card connectors for TP-650, TP-750 and - Industrial grade protection
- Safety approval: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
- Dimensions: 86mm (H) x 150mm (W) x 150mm (D)
I've got 2 sata hdd 1dvdrw wanting to OC my X6 1090t 2x2gig ddr3
thanks for your help!
it should be.
do you already have one of the hd5850 or do you still have to buy both of them?
if you still have to buy both of them then i would certainly wait and see what the 69xx are like, if its too pricey then i would think of 2xhd6870 instead.
When I had crossfire 5850 & Overclocked i7 this pulled 430w~ from the mains at full load.
What is telling you that you need 750W?
If it is a AMD, then that is mainly to account for sub-standard power supplies that flood the market. Many of these models can't really supply their rated power, so AMD overspecify to ensure that their hardware will definately receive sufficient power. However, your PSU is a high quality one that can definitely provide the rated power - so you won't have any issues.
If you would like a sensible power calculator - I find this one produces good results.
thank you for your answer that link is good! they don't have my cpu but I'm sure it doesn't make a big difference.
I've realised I was doing it wrong I put more than 1 in number of CPU....always below gives me 530w with an X4 940... so seems I've got headroom for OCing
