I recently bought and installed the X-FI xtream gamer sound card. Ive been playing FarCry 2 and Crysis Warhead, with no problems. I came to play GRID and UT3, and they just froze at the splash screens? Tried multiple times, and same result having to end the App in task manager?
All my GPU and sound card drivers are upto date. I tried to look up the problem, and it seems that the OpenAL that X-FI cards use to 'restore' sound in windows games in Vista, does not work in all games? Someone suggested that you have to disable the sound card in device manager, then re-enable the onboard sound (this allows you to play the games, but with no sound at all?). I tried that but it did not work for me?
Is there any other solutions? I thought there would be a more perminent solution by now?? Why have a 'gaming' sound card that does not work with big name games?
Hope someone can help / advise!
Vista 64bit
Nvidia GTX 280
Asus P5Q Deluxe
Intel E8400
4gb OCZ Reaper DDR2
Samsung SpinPoint F1 750gb
Vista 64bit
Nvidia GTX 280
Asus P5Q Deluxe
Intel E8400
4gb OCZ Reaper DDR2
