help - x360 pad
Mp4
Mp4
21 Apr 2006
Eastbourne
i got my xbox 360 pad today! , BUT i installed the drivers on the disk and i cant get force feedback to work on Flatout 2 :/
dont think feedback works properly with many games on it. Its not really 'force feedback' anyway really, its just a lame rumble :) mine shakes harder over 1 side than the other in crysis for some reason, thats the only game its rumbled on.
Doh okay :( ,
anyone with a x360 pad that has Flatout 2 , can someone do a screenshot of the default controller setup in game as ive fubard mine right up
anyone? (have screenshot of default setup with 360 pad for flatout2?)
cant seem to get XBCD drivers to work either :/
I installed the CD drivers then connected the pad. If you press the X thing in the middle of the pad a little screen pops up. If you click the down-arrow and then click 'Check For Updates' it should download a new update.
I can't say I've tried it in Flatout 2 as I don't have the game but quite a few games I have tried it on work perfectly (Gears Of War / Test Drive Unlimited / Colin McRae Dire).
M.
right , ill re install the basic drivers again , the software is pants for the pad .. would have thought there would have been some profiler software or something , cba to to go settings and play with controls all the time :D
http://xpadder.com/
http://xpadder.com/controllers.html
Play PC games with poor or no gamepad support
Add gamepad support to emulated, internet and DOS games
Play multiplayer games with each player using their own gamepad
Control video/music players using media or shortcut keys
Use a gamepad with a web browser or any windows application
No installation needed - Xpadder is just one executable file
Designed for Windows 98, Me, 2000, XP, Server 2003 and Vista
Full keyboard and mouse emulation
Supports up to 16 controllers at the same time for multiplayer gaming
Rumble (force feedback) and advanced fine-tuning options
Create and share any layout for any controller
Multiple profile management using sharable files
Designed for gamepads, joysticks, steering wheels, dance mats...
used this already and hated it with a passion , using Pinnacle now
still cant remember the default controls (default) for the 360 pad on flatout2 tho ...
M.
you sure about TDU? Couldn't get rumble support without usinig XBCD drivers myself.
lo all, its a decent pad but atm flatout 2 is the only game i find it fun on. I've tried to reinstall the game to try and get default settings back .. but still no luck ... and even going to default settings doesnt do anything.
