Anything you would add/change about these instructions? Also is it worth running CCleaner for good measure?
1. Turn off System Restore
- Click Start, right-click My Computer, and then click Properties.
- In the System Properties dialog box, click the System Restore tab.
- Click to select the Turn off System Restore check box. Or, click to select the Turn off System Restore on all drives check box.
- Click OK.
- When you receive the following message, click Yes to confirm that you want to turn off System Restore:
"You have chosen to turn off System Restore. If you continue, all existing restore points will be deleted, and you will not be able to track or undo changes to your computer.
Do you want to turn off System Restore?"
- After a few moments, the System Properties dialog box closes.
2. Reboot
3. Download Ad Aware SE, Super antispyware free edition and Avast from Download.com
4. Scan each downloaded file (right click and scan with AVG)
5. Install Ad Aware SE (reboot if prompted). Download the latest updates
6. Install Super antispyware free edition (reboot if prompted). Download the latest updates
7. Install Avast (reboot if prompted). Download the latest updates
8. Uninstall AVG (reboot if prompted)
9. Run Ad aware SE FULL scan & delete all it finds
10. Run Super antispyware free edition FULL scan & delete all it finds
11. Run Avast & delete all it finds (this could take a few hours)
12. Reboot.
13. Run Ad aware SE QUICK scan & delete all it finds
14. Run Super antispyware free edition QUICK scan & delete all it finds
15. Turn on System Restore
- Click to clear the Turn off System Restore check box. Or, click the Turn off System Restore on all drives check box.
- Click OK.
16. Reboot
17. Defrag
Happy computer
