HELP!
Permabanned
2 Nov 2005
stockport, cheshire
I have both XFX 7800 gtx 512mb and BFG 7900 gtx 512mb i have done a straight swap of the cards but i am only gettin like 12 - 20 fps where i got 40 - 50 on the 7800.
What is the better card? 7800 or 7900? why do i get low fps etc?
Thanks in advance
Erm, not to sure what you mean but the 7800GTX is not the same as a 7900GTX hence the difference model number, what are you getting the FPS results in, which program, more info needed I feel.
Out of the two, the 7900GTX is the better card.
Stu
Thanks in advance
just uninstall the current drivers and install beta 84.20 to get going.
84.20 extreme G V2 is the driver to install. After you find stability.
