HELP!
7 Jul 2006
Liverpool.
Right i recived my Hyundai A321 32" Widescreen HDMI 8ms LCD TV HDTV And i noticed on the left hand side of the casing it has split sort off is this ment to be like this ? :confused:
i'm not an owner but if that is along the split between the casing it has probably got dropped en route, have you tried pushing it back together, its probably just popped apart and needs pushing back together, as long as your tv works i would say its very much a visual thing rather than going to cause total tv failure!! dum dum dum! :D
If it's split open you want to ask yourself how that happened?
Then you wanna ask yourself if you're happy owning a TV which has undoubtedly been bashed or dropped?
I don't know how it happent i am getting it changed the courier is comming to pick it up tommorrow :) Then the Company
That i orderd it of will send me a new one on friday ... They are VERY Helpfull!
david334 said:
Better not to quote the competitor as well then eh....
me? i didn't... never :o
better take out the competitor linkage mate... OcUK just happen to sell that very tv ;)
