HELP!!!!!!
  • Thread starter Thread starter Zip
  • Start date Start date
Zip
Zip
26 Jun 2005
Australia
Im reformatting my computer soon :(
When i reinstall Folding how do i make sure i keep my same name and account and points?
your name and points are hosted on sanfords server so not a problem.
just install F@H as normal - username zip. Team 10 etc, etc, etc.
If your using XP I hope you've got sp2 on disk - killer of a download - on that point I did a new install two weeks ago and spent 4-5 hours on the MS website downloading and installing 'critical' update :(
Make sure to either finish the current WU (use the -oneunit flag to stop the client downloading another one) or copy the current WU to your new install. :)
assuming you're using the console client just copy the whole folder accross and run with the -configonly flag to set the service up
the client will get a new ID though that won't affect the WU you're working on - it will however show as an extra active CPU on the stats but after a week that'll sort itself out
