Help! :)
22 Dec 2004
Nottingham
Ok!
So my pc's been acting weird like its had a Virus. Anyway, i was playing a css game, then my Net crashes. i Restarted my PC and my wireless wouldnt connect. so i reinstalled the drivers. Still no luck. I swaped the pci wireless card around and cleaned my pc at the same time. I cleaned the Motherboard with a new paint brush. Since then my pc wont display. My gcard still works but nothing is being displayed on the monitor. Not even that No connection found shizzle that floats around when you d/c your gcard. Any ideas? personally i think my AGP slot might be borked
thanks
oLLy
have you tried a 24hour cmos clear (i.e. no power to comp, cmos jumpers set to clear + battery out)? or failing that try turning the comp on and holding down insert or delete to see if you can get into bios
