thanks ive done that, and their was a patch i installed before it went crazy, how do i remove the patch because when i try and install it again, it says theres a newer one installed but i want to get rid off it ?
says rundll file cannot be found so i reinstall it but i want to patch it but it says a newer one is their so i carnt patch it
