Help!
22 Oct 2002
Cardiff
Hi
Recently just upgraded my pc to the following
Intel Q6600 Core 2 Duo
Abit Quad GT Mobo
4GB Geil PC6400 Ram
Scythe Ninja Rev. B
I have 1x320Gb HD i want to install windows on and i have 2x250GB hd's raided together from the previous setup.
Once i setup the pc firstly it doesn't seem to recognise my raid array (hopefully haven't lost all my data) and secondly i cannot install windows vista, everytime it says read from cd/dvd drive it reboots. I have also tried a copy of XP and that read but does not load up.
Any help would greatly be appreciated.
Thanks
Chris
you tried setting it up with a minimum spec, cpu,gfx 1 stick memory, 1 hd, cd/dvd drive ?
did the raid drivers load okay and was raid enabled in bios ?
I haven't been able to load any raid drivers as i haven't been able to install windows yet.
I will try taking all but 1 stick out and see if that works.
Thanks
Chris
I've only got the 1 hd connected now and thats about it but it still won't load is it worth just trying it with 1 stick of ram in?
Is it possible to flash the bios without windows installed?
Thanks for the advice
Cheers
Chris
That shouldnt be the problem.
Make sure the boot sequence is set correctly, use 1 harddrive plugged in, and make sure the optical drive is working properly (if it wont read the XP discs ;\)
