Help!!!
4 Mar 2007
North West
:mad:How the hell are you suppose to remove a heatsink from a CPU that is stuck down with foooking thermal adhesive tape. Its like its cemented down!!!!! :mad:
If the processor is still in the motherboard try turning on your pc and running it for a few minutes in prime or orthos so it heats up then turn off your pc and try removing it then should be easier..
Right I will be re applying the heatsink with some artic silver 5, is there any house hold stuff i can wipe the heatspreader and the bottom of the heatsink with before i re attach
