Help
20 May 2006
ok so i am installing the Tuniq Tower 120-LFB CPU Cooler into the Antec Nine Hundred Case does this look right ?
and also in the picture i where i have circled Green this has a little play in it is this ok ?
And one more the CPU plug on the motherboard has got 4 pins but the Tuniq cooler only has 3 is this ok to ?
sorry for all the questions its me first build and i want it to go well :D Thanks a lot guys.
I have mine at 90 degrees to that, so it is blowing from front to back, towards the exhaust fan.
What do you mean by 'a little play'?
I think you have to use the rheostat (power control) to alter the speed of the fan in the TT. That's why it only has 3 pins wired (the 4th on the motherboard is for the motherboard to control the speed of the fan).
of course, sorry :o:D
As long as there isn't a gap between it and the chip, you should be all right.
Hmmm, someone else had a GB board on here today and the northbridge heatsink (the gold thing) moved a bit....
