help!!
30 Dec 2008
ok im freaking out here
i cant find a decent review
i posted here a while back and ended up building a system
heres what i got at the moment
intel quad core extreme qx6850
Asus P5e3 Deluxe Wifiap motherboard
1tb hdd
zalmann heat sink
corsair tx750w
only 2gb of ddr3
ati radeon x1600 (temporary until i decide)
im really going nuts here guys
i just built this rig then i7 rolled onto the scene
before i go buy corsair dominator ram and a 4870x2
i was thinking of dumping this rig and going i7
can someone who REALLY knows tell me whether i should just buy the ram and video card and be done or whether i should sell my mobo/cpu and add some cash and go i7
i want to be future proof for all the upcoming games, i want to not even have to think to put all the games at the highest setting
is my motherboard and cpu future proof with x ram and x video card?
is it worth going i7
if so , which one is the best bang for the buck?
which is the best i7 motherboard for the money
4970x2 or gtx285/295?
whats the best ddr3 ram?
and again all future proof
thanks for helping me out its a ton of questions but im getting extremely frustrated because my rig is not as blazing fast as i thought it would be but im thinking maybe that's just the ram
ok so im going to go with 6gb of ddr3 corsair dominator
a 4870x2 because i want overkill
but the ddr3 should i go with 1600 1800 or 2000 which one is future proof yet still not crazily expensive, is it better to go with 1800mhz of less or 1600mhz with more gb
but if i was say to sell my mobo cpu and go i7 which one would you recommend and whats the best motherboard to go with?
yes, a guy was going to sell it to me for 250$ but then flaked out on me so i never ended up having a 4870x2
and i did post here before but no one ever really gave me any advice on what cpu to buy they were just arguing about what was the right graphics card
then i had to stall on building my system because some issues came up and the moeny i had saved went elsewhere
so im justifying because i dont want to seem like a liar
i bought the qx6850 because i bought it as a combo with the mobo and 2gb of ddr3 for 400$ i had no clue what i was buying but it seemed like a good deal but now im not sure whether or not it was a good buy so im wondering whether or not i should sell it on ebay and add some cash and get an i7
so now the question lies, which i7 is the best for money, 920, 940 ..
and i cant seem to get any solid review of whats better the 4870x2 or the gtx series
i am very serious about this rig im just extremely confused
any help is appreciated
so again i did post for advice here if you search under my username but no one told me specifically of any parts they were all just generalizing
ok so final question
in order to play games on a hdtv 23" screen
if i bought a gtx295 would it still be worth it to upgrade my mobo cpu to i7
or should i just overclock what i have, thanks
if amto overclock whats the best cooling methods
