help
Its a £27, 750 watt PSU.
Its more than likely going to be a cheap 300-400 watt generic PSU with a 750 watt sticker. The give away is it uses a 20 + 4 pin motherboard plug.
Get the Hiper, it will run two of your cards and you can reuse it when you upgrade.
