Help
26 Oct 2009
Hi All
I need some help please with a problem please?? OK What happening is I put a new hard drive into my PC with 1 GB off new ram there was already 3 GB ram in the PC! I installed Windows home XP and a program that converts my photos! Now when I tried to convert my photos all i keep getting was A Worker.exe box pop up and would convert the photos. I taken out the new GB ram and it converted the photos! Cool! Well almost! Then now when i tried to look at them in the browser i am getting a box saying DDPEditor.exe box!
Now is this a ram or hardware problem or is it a software problem??
Any idea please?? I look forward to hearing from you!
All the best
Brian
Hi Plec
Thanks for getting back to me!
OK the HDD the O/S on 160GB and there a 500GB too It a core intel 2 CPU 6400 @ 2.13Ghz the ram DDR2 1024mb 533mhz i the new ram is different to the old 3GB. Yes it has four slots.
I am running XP home as the o/s.
How do you run memtest on the new stick please?
All the best
Brian
The motherboard a Asus P5B The memory 3GB is the same type the 4 different the grx is a ATI radeon HD4600 serices The PSU it a capricorn case so not sure on the power to that?
