Help =[
22 Jan 2010
Don't really know where to post it, so this seemed like the most suitable place. But anyway I recently started using my old PC as I wanna do a bit of gaming and my laptop ain't really that good for it, I reinstalled XP on it but I seem to have lost the Ethernet Controller driver, so I can't connect to the internet. My motherboard is a FOXCONN MCP73, I went on their website and couldn't find any information about the driver I need. I also downloaded this program which apparently tells me what drivers I am missing and what is needed, but that doesn't work either so I don't really know what to do? Any help please =]
Well I installed the nForce driver and some of the things under "Other Devices" in my device manager have gone, but their Ethernet Controller one is still their so its still not working =[
Is the port on onboard ethernet port or a PCI card one?
I had the same problem with a MSI k7T turbo mobo, complete ****e it was.
otherwise if you have windows 7, install that and that should fix it? thats what I did for my problem.
Seriously this is really bugging me downloaded 3 different ones which say it installs Ethernet Controller driver but none work, someone please help...
