Help!
17 Dec 2009
Wales
My dad needs a car ,if it helps he likes classic cars , eg ford capri , ford cosworth RS.
Needs to be under £1000 , cheap to run and maintain.doesnt need to be pratical. everything I have shown him , MX-5's ect he doesnt like :rolleyes:.
He'll struggle to get a Capri worth having for that budget - they have been appreciating steadily for a few years now. I think he'll need to spend nearer £1500 - £2000 for a halfway tidy 1.6 or 2.0 Capri (2.8 should be over that budget unless it's a bit of a nail)
Look for rot on the sills, strut tops, wings, rear 3/4 "pockets", B-posts, battery tray - pretty much anywhere you'd expect a 70s/80s car to rot really. Mechanically they are pretty much bombproof aside from the Pinto engine which can develop cam issues and a smoking habit when the miles pile up.
***** sake , he has just gone and bid £1050 on a ford capri that looks like it needs a lot of work done. what an idiot he is.
They are not going to be cheap in the slightest. Tell him if he really wants one to spend double this budget on a good one so he doesn't have to spend so much running it.
He's asking for trouble and really can't expect anything other than problems with a £1k classic car.
Classic Vehicle, thats cheap to run for under 1k !!!? hmmmmm
My Manta has been exceedingly cheap to run. In fact at the moment it probably only owes me £50 more than the Mondeo did over a similar timescale. You do need to know one end of a spanner from the other of course.
This Capri is a bit over budget but looks about right for the money:
http://www.carandclassic.co.uk/car/C127942/
There's nothing in that listing that indicates it needs a lot of work done :confused:
If that Capri doesn't fetch well over 2k with 11 months ticket I will be extremely surprised.
Pinto lumps look hilarious in Capris, you could stand in the engine bay with the engine still there! When you buy a Capri, you buy a V6, it's the law :)
The Capri listed looks fine and will go for a lot more than £1000.
