Help
Permabanned
22 Feb 2010
Hi all.
I have a 9800GT here.
It works fine with both HDMI and DVI-D on my Monitors.
When i try to connect a DVI-VGA conveter then to a VGA only Monitor it gives no signal At all.....
Any ideas here?
Monitor works fine on other branded 9800GT.
Tryed diffrent adapter and cable
sorry re-read and understand now, but can you tell me more about what other screens if any plugged in and what connection.
Ok
The other monitors (two of them) have only blue VGA connection.
So i go ahead and plug a DVI to VGA adapter into the Card and no signal on the monitors...
Try again with a DVI-VGA cable and same thing.
Ones a HansG 22" and ones a Old dell 17"
When plugged into my Dell 2408 via HDMI and DVI-D its all fine
