- 2 Feb 2008
- Rainham - Kent
Got a weird problem occurring and was wondering if any of you could shed some light on the situation as maybe it might of happened to you before. I'm not really clued up on gigabite motherboards have tended to use Asus in the past so it could be some setting I am missing or not using I really just don't know.
The System:
GA-X48-DQ6 GIGABYTE MOTHERBOARD
E8400 CPU
4 X 1GB STICKS OFPC3 10666 PLATINUM EDITION
Anyhow I have clocked the machine to 444x9 = 4.0ghz and its stable and fine and with only 2 sticks of ram it runs nice and fast and plays games as it should. just as a test it also does super pi 1m in just over 11 seconds which I would say is about right for this pc, the problem starts when I add the other 2 sticks of ram although the pc is stable it runs slower a lot slower - super pi 1m takes 19 seconds to do the same test and games are now laggy. As soon as I go back to just 2 sticks each time its fine again. Obviously if I can I would like to use all 4 sticks.
Anyone got any idea what the problem could be??
The System:
E8400 CPU
