help ?
1 Oct 2010
okay im having problems with my memory its running at 534.0mhz when it should be running at 1800 i have tryed setting x.m.p in the bios but my pc wont boot after i then tryed the memery level up and set it to 1800 which worked but when i looked at the volts on gpuid hw monitor it says its at v 2.00 which is way to high and i cant see anywhere in tho bios to change this
mem = http://www.overclockers.co.uk/showproduct.php?prodid=MY-271-CS&groupid=701&catid=8&subcat=1392
motherboard = http://www.overclockers.co.uk/showproduct.php?prodid=MB-319-AS&groupid=701&catid=5&subcat=1692
