Help!!!!
31 Jul 2011
Dear All,
I left my computer on last night to finish a download (Vindictus). Before I left I set the power options to hibernate after two hours.
When I woke up my computer was resetting its self constantly (hopefully not for long, but it could have been for 8 - 9 hours!!!).
I checked the reset switch.... its not the problem + the mother board reset switch jumper is in the correct place.
Next I removed the Bios Battery and placed it back in after a minute... no result.
Next I removed the GPU, thinking the power supply could be overloaded (750 Watt Bronze Plus). It didn't work.
I would really appreciate some help.... I'm at a loss as to what to do.
PC-
i5 2500k
Ati 6950 Toxic (2GB)
Crucial RealSSD M4 128GB
Gigabyte Z68XP-UD3 Intel Z68
Lepa B-Series 750W '80 Plus Bronze
Zalman Z9 Plus Tower Case
Kingston HyperX Genesis Grey 8GB
OS: Win 7 64
Sorry.... didn't work. I just came back to it and the same again
Randomly started to work... It was attempting to boot using the cached windows session (from hibernation) that most have been in the SSD....
Never turn on Hibernate!!!
Just loaded windows....
At 3 AM last night the system entered hibernation in the middle of a windows update!!!
I performed a system restore to before the update. Everything is fine now!!!
