Help!!
Permabanned
6 Sep 2011
Finished putting together my build...
Every time I start the computer it powers for 5 seconds then resets and continues to do that. I have no idea what it is... But with the new build I got the antec 920.... Could be that but it does start up...
Specs? ( i could look at past threads from yourself, but im lazy)
Have you got the extra 4/8pin in to the motherboard near the CPU socket?
Try a CMOS reset?
i had a simuler problem first of all make sure in bios youve set it to achi i had to do a bios update then touch wood its been fine just seen your latest post thats why i updated bios wouldnt let me get in kept comming up with b2
unplug and remove battery i tried that but it didnt help can you down load the new bios from another pc and put it on a pen drive
Heres another try,
Remove all RAM.
Power up, then Power OFF.
Take a single RAM stick and place it in the slot furthest away from the CPU.
Power up, anything?
If not move this RAM stick a slot closer and repeat, keep moving it closer each time.
So to be perfectly crystal clear,
You have tried the new RAM in the other PC and it now doesnt work?
