DCUII should clock to 840/1325, higher if your accept the UELA thing in afterburner. Had mine up as high as 900/1350 on stock volts.
Can it be flashed or not I don't know, but if it can you'd be safer just unlocking the shaders and then overclocking to 6970 speeds (around 880/1375 iirc).
