Help
31 May 2012
Help - Issues with monitor ?
Hey guys i have a problem.:mad:
Here the story.. I was doing windows updates last night.. I fell asleep and woke up to check on my updates to find my monitor would not go on its like
in a sleep mode. I turned off system from switch and turned it on to find a loud noise coming from the case i opened it to find the graphics card fan going really fast but still the monitor isnt going on.
Help?
Any number of things could be causing this. Firstly put up your computer specs including power supply. Secondly, is the monitor itself working? (when you pull out the cable from the back of the pc with the monitor turned on does it display a test pattern?)
Thirdly, do you overclock?
Intel i5 3.4GHz (stock cooler)
8GB DDR3 Kingston RAM
2TB Hard drive
Psu CX 500 Corsair
GTX 550 Ti
Motherboard is Biostar b75mu3
No overclocking as of yet. Monitor is fine just tryed it on my laptop
Hmmm Biostar.. Sounds interesting.
Have you tried the process of elimination game yet? Just take out things one at a time and try and find the culprit. It may well be the updates though. Can you even get to the bios or is it just no post at all?
No display + graphics card fan going mental probably means a failed graphics card.
Take out the graphics card and try the onboard graphics and see if that works.
No the screen just stays in a sleep mode state. Could this really be updates that caused this ?
Is Biostar ****e ?
Some updates can conflict yeah but the I only really thought of updates as you said you were installing them and now your PC is borked.
Try Blue's option first and see what happens.
Have you tried booting in safe mood and restoring to before updates when problem started?
Have seen seen updates do things like this before on more than one occasion so is first thing I would try.
This. Don't even bother to open a case or fiddle with things until you do a System Restore to see if that works.
As often as not you will get a screen in safe mode because it boots safe.. without all the bells, whistles, drivers, etc. you normally boot with. ;)
We aren't saying it will work, but is the FIRST thing to try with you experience issues after and update. It's far more likely an update issue then a GPU issue... and restoring to what you had before update remove the updates.
