Hi this is what CPU-Z says
Binaries
CPU-Z version 1.69.2.x64
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.215 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 2500K
Codename Sandy Bridge
Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
Tjmax 98.0 °C
Core Speed 1596.2 MHz
Multiplier x Bus Speed 16.0 x 99.8 MHz
Stock frequency 3300 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 33x
Max turbo ratio 37x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 37x
Ratio 2 cores 37x
Ratio 3 cores 37x
Ratio 4 cores 37x
TSC 3292.6 MHz
APERF 2195.0 MHz
MPERF 3292.5 MHz
Chipset
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel Z68 rev. B3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual
Memory Frequency 665.1 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CMX4GX3M2A1600C9
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 8.0-8-8-22-30 @ 592 MHz
JEDEC #3 9.0-9-9-24-34 @ 666 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.650 Volts
Min Cycle time 1.250 ns (800 MHz)
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-6-6-16-27-2T @ 533 MHz (1.650 Volts)
XMP #2 9.0-9-9-24-41-2T @ 800 MHz (1.650 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
AMP no
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 3
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
AMP no
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 4
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
AMP no
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
Monitoring
Mainboard Model Z68MA-D2H-B3 (0x000002E3 - 0xAC205A60)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x1
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 1.03 Volts [0x56] (CPU VCORE)
Voltage 2 2.99 Volts [0xF9] (+3.3V)
Voltage 3 5.00 Volts [0xF8] (+5V)
Voltage 5 -3.94 Volts [0x52] (-12V)
Voltage 6 -6.05 Volts [0x7E] (-5V)
Voltage 7 2.84 Volts [0x8D] (+5V VCCH)
Voltage 8 1.61 Volts [0x86] (VBAT)
Temperature 0 37°C (98°F) [0x25] (TMPIN0)
Temperature 1 32°C (89°F) [0x20] (TMPIN1)
Temperature 2 21°C (69°F) [0x15] (TMPIN2)
Fan 0 837 RPM [0x326] (FANIN0)
Fan 1 842 RPM [0x322] (FANIN1)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.88 Volts [0x36B] (VIN0)
Temperature 0 40°C (104°F) [0x28] (TMPIN0)
Fan 0 1950 RPM [0x79E] (FANIN0)
Fan PWM 0 40 pc [0x28] (FANPWMIN0)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0100
Revision ID 0x09
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0101
Revision ID 0x09
Description VGA Controller
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0112
Revision ID 0x09
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C3A
Revision ID 0x04
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C2D
Revision ID 0x05
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C20
Revision ID 0x05
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C10
Revision ID 0xB5
Location bus 0 (0x00), device 28 (0x1C), function 6 (0x06)
Common header
Vendor ID 0x8086
Model ID 0x1C1C
Revision ID 0xB5
Location bus 0 (0x00), device 28 (0x1C), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x1C1E
Revision ID 0xB5
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C26
Revision ID 0x05
Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xA5
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C44
Revision ID 0x05
Description Serial ATA Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x1C02
Revision ID 0x05
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x1C22
Revision ID 0x05
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x06CD
Revision ID 0xA3
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0BE5
Revision ID 0xA1
Description Ethernet Controller
Location bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x06
Description USB Controller
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B6F
Model ID 0x7023
Revision ID 0x01
DMI
DMI BIOS
vendor Award Software International Inc.
version F9
date 10/12/2011
ROM size 4096 KB
DMI System Information
manufacturer Gigabyte Technology Co. Ltd.
product Z68MA-D2H-B3
version unknown
serial unknown
UUID {00000000-0000-0000-0000-50E54938FCC6}
SKU unknown
family unknown
DMI Baseboard
vendor Gigabyte Technology Co. Ltd.
model Z68MA-D2H-B3
revision x.x
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i5-2500K CPU
clock speed 3700.0 MHz
FSB speed 100.0 MHz
multiplier 37.0x
DMI Memory Controller
correction 8-bit parity
Max module size 1024 MBytes
DMI Memory Module
designation A0
size 2048 MBytes (single bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation No Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Port Connector
port type USB
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 32768 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 2304 bits
data width 2252 bits
size 2048 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
size 2048 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
size 2048 MBytes
DMI Memory Device
designation A3
format DIMM
type unknown
size 2048 MBytes
Graphics
Number of adapters 2
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY1
Name Intel HD Graphics 2000 (GT2)
Board Manufacturer GIGABYTE Technology
Technology 32 nm
Memory size 3862 MB
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1458)
Model ID 0x0112 (0xD000)
Performance Level 0
Core clock 850.0 MHz
Display adapter 1
Name NVIDIA GeForce GTX 470
Board Manufacturer ASUSTeK Computer Inc.
Revision A3
Codename GF100
Technology 40 nm
Memory size 1280 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x06CD (0x8342)
Performance Level Default
Core clock 50.5 MHz
Shader clock 101.0 MHz
Memory clock 135.0 MHz
Performance Level 2D Desktop
Core clock 405.0 MHz
Shader clock 810.0 MHz
Memory clock 324.0 MHz
Performance Level 3D Applications
Memory clock 1674.0 MHz
Core clock 607.5 MHz
Shader clock 1215.0 MHz
Win32_VideoController AdapterRAM = 0xF168E000 (4050182144)
Win32_VideoController AdapterRAM = 0x50000000 (1342177280)
Win32_VideoController DriverVersion = 8.15.10.2321
Win32_VideoController DriverVersion = 9.18.13.3788
Win32_VideoController DriverDate = 03/06/2011
Win32_VideoController DriverDate = 05/19/2014
Software
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
