HELP?
29 May 2014
Cardiff
Hey guys, so I finished my build this morning, PC was up and running perfectly. However I went out about an hour ago and when i came back there was no signal coming through to the monitor, I tried another monitor and another input socket but nothing. Its plugged into the motherboard input VGA. Iv'e tried resetting computer, turning off/on etc unplugged mobo/ took out CPU and put back in. No luck? I have a Gigabyte Z97 HD3 with I5 4670k.
Help appreciated.
Thanks.
I ordered an R9 270x which is due this week, but I don't currently have one to slot in.
clear cmos? Whats that? sorry I am new to all this :')
there will be a jumper or button to basically reset all the settings on the motherboard to default look in your manual it will show where there.
No success, I removed the battery for a minute or two, It did not work.
Any Ideas guys??
Take the power lead out when you do the cmos battery too.
Are you getting a beep at all.
Check cable seated ok in both pc and monitor.
