HELP
30 Mar 2013
I'm experiencing a strange issue, when I first boot up and play a game I'm getting flawless performance, but after about 10 to 20 minutes my FPS drop by half. the GPU is running between 60 and 70 degrees and the CPU below 60 degrees. I have done a disc and memory check and they both came back good. I have done a driver sweep and a clean install of the drivers and that didn't solve the issue, so I am at a loss as to what could be causing the issue. Any help would be greatly appreciated.
Well I was getting BSOD when I tried to enable shaowplay but judging from some forums its a common issue, my pc seems to be running ok. I'm using a hdd, 500gb seagate and I have a 1tb hdd installed aswell. Really annoying, I waited for the PC version of GTA v an now this happens.
