Can anyone help me please. I have a Nokia 1plus. The phone after 1 week is struggling with speed and storage. I put a sd card in to cure the problem. HOW DO I TRANSFER APPS AND FILES TO THE SD CARD?? nothing works and the card has been formatted.
When you formatted it did you get the option to use it as internal or portable storage ?
If there was no option then you can't transfer apps to the sd card.You can only use it for app data and any music,pics or vids you have.
