Help!
18 Sep 2007
Ho all,
Bit of a strange one so i thought i would post to see if anyone has seen it before..
I am just rebuilding an old machine for a friend and i have it up and running but when i plug the power switch on to the motherboard and turn it on the pc starts up and shuts down again.
So if i leave the switch off and boot it from the power switch on the motherboard it boots fine.
i have the machine up and running with a fresh install on it so i know the mobo isnt faulty?
i have the switch on with the writing facing out the same as all of the rest? it's very odd.
has anyone had any experience with this?
its an asus P8z68-v Gen 3 mobo with an i7 in it...
Any advice you can offer would be great,
Thanks all.
