Looking at the product page for the case, it says up to 240mm radiator on the front or 3 120mm fans.
If you cut a deeper hole at the front where the lowest 120mm fan fits (see image), then you *might* be able to attach a 360mm radiator, otherwise with no modding, it's not possible.
