Help1 which board to keep.
2 Jul 2007
Cheshire East
Need some help to decide what to do. My system is mainly for gaming and burning the odd cd and generally msn etc etc
I have a Q6600go on a Maximus formula MB. I also have a GA-EP45 extreme which i bought last week. But i was'nt that impressed with it so went back to my Asus.
The thing is i have been thinking of getting a newer cpu maybe the Q9550. The question is if i got the newer cpu would it perform better on the Asus or the Extreme M/B. I have read that the Extreme M/B is optimised for the newer chips so maybe when i ran the Q6600 on it i was not seeing it at its best.
so the question is
Do i keep the Asus or the Extreme....and should i keep the 6600 or get the 9550...and which cpu should i use with either board to get the best performance.
My full rig is Radeon 4850
2x 640 WD Blacks in raid 0
4 gig of gskill pc8000
Kandalf lcs case.
thx in advance.
I would use the Gigabyte with a Q9550 if you're intending to overclock it.
Is that because it is newer technology and is more optimised...i am asking because if i decide to crossfire later...i will only get 8x8 on the cards with the Extreme, as opposed to 16x16 on the asus....or would the difference in performance between the 2 be none noticable from a graphics point of view.
thx
Difference won't really be noticeable.
But the P45 chipset is far better at overclocking the 45nm quads than the X38 chipset (tho X38 should still take a Q9550 to ~3.9ghz).
