Hi there
We've now got all the latest HerculeZ iChill Inno3D 7xx series graphics cards in stock. The HerculeZ coolers are really something else, pretty much winning all reviews for cooling ability, yet still remaining pretty quiet on the noise levels, check them out:-
inno3d geforce gtx 780 ichill herculez x3 ultra 3072mb gddr5 pci-express graphics card @ £629.99 inc vat
the new geforce gtx 780 is all about hyper-realistic gaming and next generation technology. the geforce gtx 780 features the same record-breaking gk110 gpu used in geforce gtx titan. the massively powerful nvidia kepler ™ based gpu contains 50% more cores than its gtx 680 predecessor and comes with 3gb of high-speed gddr5 and nvidia gpu boost 2.0 technology. geforce gtx 780's 384-bit memory interface provides up to 288.4gb/sec of peak memory bandwidth to the gpu. all this combines to give you over a 40% gaming performance upgrade.
features:-
- gigantic 3gb gddr5 memory for the best gaming experience & the best resolution
- nvidia gpu boost 2.0 technology for intelligent monitoring of clock speed, ensuring that the gpu runs at its peak and the game is at its highest frame rate possible. it offers new levels of customization, including gpu temperature target, overclocking, and unlocked voltage
- nvidia adaptive vertical sync adjusts vsync to current frame rates for maximum playability
- bring games to life with nvidia® surround™ multi-monitor gaming on a single card
- pci express 3.0 delivers double bandwidth per lane of pcie gen 2 for faster gpu - cpu communication
specification:-
- gpu: geforce gtx 780
- core base clock: 1006 mhz
- core boost clock: 1046 mhz
- memory clock: 6212 mhz
- memory size: 3072mb gddr5
- bus type: pci express 3.0
- memory bus: 384-bit
- cuda cores: 2304
- memory type: 64mx32
- directx 11.1: yes
- dvi port: dvi-i /dvi-d
- displayport: yes
- hdcp: yes
- hdmi: yes
- warranty: 2yr
only £629.99 inc vat.
order now
inno3d geforce gtx 770 ichill herculez x3 ultra 4096mb gddr5 pci-express graphics card @ £419.99 inc vat
the next generation geforce gtx 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. it features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
features:-
- innovative new geforce architecture, designed to deliver faster, more power-efficient performance
- nvidia gpu boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- the power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with nvidia fxaa
- the power of 3-way nvidia sli® technology
- ultra-smooth gaming experience with exciting new nvidia technology advancements
- nvidia 3d vision® surround multi-monitor gaming on a single gpu (three gaming monitors plus one accessory display) - for the first time ever
- supercharged nvidia physx® and nvidia 3d vision® performance
- new 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
specification:-
- core clock: 1150mhz (gk104)
- core boost clock: 1196mhz
- memory: 4096mb gddr5
- memory clock: 7200mhz (effective)
- memory interface: 256-bit
- processing cores: 1536
- shader clock: 2170mhz
- bus type: pci-express gen 3.0 (backwards compatible)
- display connectors: 2x dual-link dvi-i, 1x hdmi 1.4a & 1x displayport
- sli ready (upto 3-way sli supported)
- hdcp capable
- directx 11 support
- opengl 4.0 support
- physx enabled
- cuda enabled
- 3d vision enabled
- nvidia surround enabled
- lower power consumption (maximum consumption 230 watts at stock speed)
- 1x 8-pin & 1x 6-pin pci-e connectors required
- warranty: 2 years
only £419.99 inc vat.
order now
inno3d geforce gtx 770 ichill herculez x3 ultra 2048mb gddr5 pci-express graphics card @ £379.99 inc vat
features:-
specification:-
- memory: 2048mb gddr5
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
only £379.99 inc vat.
order now
inno3d geforce gtx 770 ichill herculez 2000 2048mb gddr5 pci-express graphics card @ £359.99 inc vat
the gtx 700 series is the latest generation of breakthrough nvidia® kepler™-powered gpus, launching may, 2013. the family is built for performance—fast, smooth, whisper-quiet and loaded with advanced game-ready capabilities like geforce experience™. this means deeper, richer, and more immersive gaming than you can get anywhere else. all cards in the 700-series platform (gtx 780, 770, and 760 gpus) will offer a truly impressive pc gaming experience.the gtx 700 series is the latest generation of breakthrough nvidia® kepler™-powered gpus, launching may, 2013. the family is built for performance—fast, smooth, whisper-quiet and loaded with advanced game-ready capabilities like geforce experience™. this means deeper, richer, and more immersive gaming than you can get anywhere else. all cards in the 700-series platform (gtx 780, 770, and 760 gpus) will offer a truly impressive pc gaming experience.
features:-
specification:-
- core clock: 1071mhz (gk104)
- core boost clock: 1111mhz
- memory clock: 7010mhz (effective)
- shader clock: 2142mhz
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
only £359.99 inc vat.
order now
inno3d geforce gtx 770 oc 2048mb gddr5 pci-express graphics card **titan cooler** @ £359.99 inc vat
this inno3d card is extremely special as it uses the incredible cooler found on nvidia's titan, which looks absolutely amazing and is ideal for exhausting heat out of your case.
features:-
- titan cooler!!
specification:-
- titan cooler!!
- core clock: 1045mhz (gk104)
- core boost clock: 1084mhz
- shader clock: 2220mhz
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
order now
inno3d geforce gtx 760 ichill herculez 3000 2048mb gddr5 pci-express graphics card @ £259.99 inc vat
the unveiling of the ichill geforce gtx 760 2gb herculez 3000 arrives. game performance and image quality has received a tremendous boost, enabling film-like geometric realism for game characters and objects. geometric realism is central to the gtx 760 architectural enhancements for graphics. in addition, physx simulations are much faster, and developers can utilize gpu computing features in games most effectively.
geometric realism is central to the ichill geforce gtx 760 architectural enhancements for graphics. in addition, physx simulations are much faster, and developers can utilize gpu computing features in games most effectively. due to that, gaming performance and image quality has received a tremendous boost, enabling film-like geometric realism for game characters and objects.
heatpipes are an efficient way of moving heat from one area to another and are usually used to connect the high density block of the cooler with the large surface area fins.
specification:-
- core clock: 1060mhz (gk104)
- core boost clock: 1124mhz
- memory clock: 6200mhz (effective)
- processing cores: 1152
- shader clock: 2120mhz
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- lower power consumption (maximum consumption 170 watts at stock speed)
- product review: http://www.vortez.net/articles_pages/inno3d_ichill_geforce_gtx_760_review,1.html
- Warranty: 2 Years
Only £259.99 inc VAT.
ORDER NOW
Great cards and remember all the iChill models also feature black PCB so look absolutely superb as well.
features:-
specification:-
- cuda cores: 2304
- directx 11.1: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- warranty: 2yr
order now
features:-
specification:-
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
order now
features:-
specification:-
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
order now
features:-
specification:-
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
order now
features:-
- titan cooler!!
specification:-
- titan cooler!!
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
order now
specification:-
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- Warranty: 2 Years
ORDER NOW
