- 21 Dec 2019
- Planet Thanet
just got a quest 2
not a happy experience so far
on the connecting it to pc side of things
first problem as in title
says not enough space to install the oculus/meta link software
turns out the reason for this is
if your windows drive is using a dynamic disk
so nothing at all to do with how much space you have
how to fix it
Locate where your OculusSetup is (downloads or wherever you put it)
In the address bar, clear it and type cmd then press enter
Then copy and paste this is into the command console that opened
OculusSetup.exe /drive=D
may need to change drive=D depending on your drive letters and what drive you want it on
cant be a dynamic disk
so if you only have 1 drive and its dynamic this wont fix it
would have to convert your dynamic disk to basic disk
how to fix it
