HeXen : Edge Of Chaos - Doom 3 Total Conversion
Caporegime
8 Sep 2006
On Ocuk
http://www.hexenmod.com/about.php
heXen:Edge of Chaos will be a new and free game, based on the original Hexen game that was developed by id Software and Raven Software. In order to play this game you will need to have the game called Doom3 installed, which was released end of 2004 by id Software.
It will contain the clerics first hub which consists of 3 full maps and some 1.5 to 2 hours of gameplay. You will fight monsters, solve puzzles, fail puzzles, use weapons, utilize artifacts, break lots of stuff, and curse our names to Chaos when you most likely die a few times along the way
first playable version of Hexen: Edge of Chaos for November 2010!
Having played it for a few hours now I can recommend it whole heartedly. The large areas had me thinking that it might have worked well if idsoftware had done something similar. If you like the older fashioned games like Quake, Heretic etc then you should like this a lot. It makes you think in way more reminiscent of the way older titles used to, perhaps due to graphical limitations and different game play mechanics / styles.
As advised, if you are running a crossfire set-up as I am, then you may find it better to disable it. The use of colour and lighting is quite stunning at times.
Will upload some more pics during the week.
