Hey all, how is this spec? and how much to have OC build it?
Hi and welcome.
Its not bad, but I am able to improve upon it.
YOUR BASKET
1 x MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £269.99
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£14 Saving** £252.58
1 x SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - Black £99.95
1 x Phanteks Enthoo Pro Mid Tower Enthusiast Case with Window £89.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLRED38G2133HC11ADC01) £65.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £39.95
1 x Raijintek Themis Evo Professional CPU Cooler £27.95
Total : £1,013.96 (includes shipping : £8.00).
Bigger SSD.
You don't need thermal paste as coolers come with some to use.
Bigger wattage PSU should you wish to add a 2nd GFX card in SLI.
Free delivery due to the PSU+case - http://forums.overclockers.co.uk/showthread.php?t=18630207
Don't spend £45 on fans, just get a better case to start with.
Rough cost for OcUK to build it is around £60.
Thanks for the welcome!
Awesome, I have made a few changes based on your suggestions. Im trying to get it just under £1000 really, although 20 quid wont break the bank.
YOUR BASKET
1 x SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black £85.99
1 x Crucial MX100 128GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT128MX100SSD1) £54.98
5 x Noiseblocker BlackSilent Fan XK2 - 140mm (1100rpm) £8.99 (£44.95)
1 x Arctic Silver 5 Thermal Compound (3.5g) £8.99
Total : £1,028.93 (includes shipping : £8.00).
I'm just wondering how much something like this would cost for the OcUK guys to build =D. I am also curious about SSD's, do I need to get a separate one and a regular HDD? or would one of them Seagate SSHD hybrid things do the job? it works out a little cheaper with one of them instead.
Thanks again for your advice!
Again I dont know why you are adding five fans to the case.
You may as well get the next case up,
YOUR BASKET
1 x Phanteks Enthoo Luxe Full Tower Case - Black £119.99
Total : £129.59 (includes shipping : £8.00).
128Gb SSD doesn't last long with all this modern games having huge install sizes, get the 256Gb MX100.
I add some pointers to my first post, have a read.
Thanks for the help. I was adding fans because some of the reviews on these cases have stated that the stock fans can be pretty noisy, especially the front 200mm one, so figured i would swap that out for 2 140mm and then fill out the case with the other 3. Maybe I am going OTT with that though. Can't believe everything you read i suppose.
Must get some sleep now, Ill be back to finalize the build tomorrow.
Thanks very much =]
