- 7 Feb 2014
- Lancashire
Hi,
Just dropping in to say Hi as I'm new to the forums, my current rig specs are below. I'll be looking to get a new GPU and add it to the loop in the near future if anyone has any recommenations as I'd won't be going for XFX this time round. As I'll be adding an aftermarket water-cooling block any manufacturers that do not void my warrant would be good
CPU: AMD FX 8350 (4.2) GPU: AMD XFX 7870 2GB DD
Motherboard: Asus Sabertooth 990FX / Gen3 R2.0
Main Drive: Kingston Hyper 240GB SSD in RAID 0 (2x120GB)
Memory: Corsair Vengeance 16GB DDR3 1866 (4x4GB)
PSU: Corsair AX860 Platinum OS: Windows 7 64
Air Cooling : Bitfenix Spectre Pro Green Fans (200mm x3, 140mm x3 120mm x1)
Water Cooling: EK Supremacy CPU Block, Hardware Labs 240mm Radiator, Alphacool XF45 140 radiator, Frozen Q 400mm Reservoir, EK DCP 4.0 Pump, Monsoon Compression Fittings, Masterkleer UV Dark Green Tubing and Mayhem X1 Purple Coolant.
