- 23 Sep 2008
New system buidl with an x38mobo. Im looking to run Crossfire at some point, so dual 4870.
I Run a 1600x1050res atm, can really see me going higher in the near future andthing bigger than 21" will make me go blind.
Basically im trying to decide between a 512mb card and a 1gig card. Whichever i get will be doubled in about 2-3 months.
The only 1gig card i can see is the powercolour with stock cooler, i quite like using no stock, i have a zalman v1000 on an old 8800 would that fit this card?
So which would you reccommend? Ive specced a 850W PSU, should this be enough power?
Cheers!
Cheers!
